moos Posted April 21, 2017 Author Share Posted April 21, 2017 I'd bet there's people on IFSJA or FSJNetwork that have a vector drawing for those decals, or know a decal place that does... There's a lots of priss types on there that seem to have the most inane things documented. :laughin:I'd join there but idk, I'd have to make a new thread an manage two threads seems like alot of work, prolly should though... Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
Dzimm Posted April 21, 2017 Share Posted April 21, 2017 Anyone know how to find or save a decal? Reads ( camper special). Just wondering what to do when i paint it. Sent from my SM-G900V using Tapatalk AFAIK there isn't a way to remove a sticker decal to reuse. If you take a really good picture of it with a ruler to show scale, you can have one made cheap or do it yourself if you have the know how.Wonder if I put a piece of paper an use a pencil if it would work Sent from my SM-G900V using Tapatalk Is the sticker raised? If so a pencil or chalk would work to make a copy. It would be easier to use a good quality picture though as the sketch would be harder to reproduce since it wouldn't give perfect edges. A graphics company or even yourself could make a copy of it using a good photo and software like photoshop to create an exact copy. If I had photoshop I would be willing to help you out but I do not. Maybe a member on here does? Link to comment Share on other sites More sharing options...
moos Posted April 21, 2017 Author Share Posted April 21, 2017 Anyone know how to find or save a decal? Reads ( camper special). Just wondering what to do when i paint it. Sent from my SM-G900V using Tapatalk AFAIK there isn't a way to remove a sticker decal to reuse. If you take a really good picture of it with a ruler to show scale, you can have one made cheap or do it yourself if you have the know how.Wonder if I put a piece of paper an use a pencil if it would work Sent from my SM-G900V using Tapatalk Is the sticker raised? If so a pencil or chalk would work to make a copy. It would be easier to use a good quality picture though as the sketch would be harder to reproduce since it wouldn't give perfect edges. A graphics company or even yourself could make a copy of it using a good photo and software like photoshop to create an exact copy. If I had photoshop I would be willing to help you out but I do not. Maybe a member on here does?Yea its raised , I just hope I can save the look or reproduce it, I haven't seen any with the decal. Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
moos Posted April 28, 2017 Author Share Posted April 28, 2017 Cleaned the oil pan an painted , i couldn't find a non cork gasket gasket anywhere so going to use the "right stuff"-permatex . Used the sealant on the bottom half of the relocation kit(worked good), top half I made a 90 degree bracket an used my stock holes for the regulator?no idea I'm guessing because it looks stock location. The brass fittings I picked up at lowes male to female 3/8 work fine uptop , the 1/2 male to female doesn't they hit eachother, so I'm using one straight 2in brass pipe to a female 90. Everything i have is a mock up once I figure the right angle I will use yellow gas pipe tape tighten down n post pics. Also i need help with the hi-6 gold box, from what I see red an black are hooked up but everything else is not besides a small green wire that was disconnected and another group of wires are zip tide, much help is appreciated. Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
moos Posted April 28, 2017 Author Share Posted April 28, 2017 Couldn't find my yellow pipe tape but white should be fine idk. Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
moos Posted April 28, 2017 Author Share Posted April 28, 2017 These are the wires to the HI-6 only the red+ ,an black- are hooked up, then two sets of two wires come out ones red n black others black an orange. Then I have 4 small wires, dark blue ,red,white, and green. Much help is appreciated ty. Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
moos Posted April 30, 2017 Author Share Posted April 30, 2017 Fabd up a shorter hard line for my power steering pressurized line, I let the gasket on my oil pan cure 24 hrs and will torque the bolts to w/e the book calls for, oil goes in tomorrow unless my powersteering pulley gives me trouble looks cockeyed a lil. Hopefully I have oilpressure tomorrow... Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
moos Posted May 3, 2017 Author Share Posted May 3, 2017 Yes I have oil pressure sweet baby jeebus,besides the hard line on the power steering pump which I have to swap no leaks, Still need to tackle wires. Link to comment Share on other sites More sharing options...
