jpdriver1 Posted April 28, 2014 Share Posted April 28, 2014 Well for the third time the 89 has failed smog -- 15 mph readings; O2 3.3 HC 7 CO 0.00 NOX 1866 gross polluter level is 1800 25 mph reading; O2 1.0 HC 2 CO 0.00 NOX 538 Items replaced to date; plugs, rotor, dist cap, air filter, catalytic converter, egr valve, O2 sensor (bosch), fuel pressure regulator, fuel filter vacuum lines all checked/routed properly bottle of chevron "guarantee to pass" stuff run through it currently has 91 octane fuel in it temp reading is just over the first line all the time mileage is 169,000 open cooling system, 3 row radiator --- three months since change over running too cool maybe? I've run out of ideas Link to comment Share on other sites More sharing options...
airspeed Posted April 28, 2014 Share Posted April 28, 2014 Your temp gauge may not be accurate but those engines need a minimum temp or 195 and I believe the ideal temp is 210. Link to comment Share on other sites More sharing options...
jpdriver1 Posted April 28, 2014 Author Share Posted April 28, 2014 too true -- it has a new stock stat in it --- thanks Link to comment Share on other sites More sharing options...
gogmorgo Posted April 28, 2014 Share Posted April 28, 2014 I'm not an expert in emissions testing in any way, but I'm curious as to why you're running 91 octane. If your engine isn't tuned for it, it's not going to improve anything. If anything, it might make things worse because it doesn't ignite as easily as lower octane. I've heard a few people recommend bombing down a freeway for 10-15 minutes, some say in a lower gear than normal, to get the cat good and hot. Might help reduce NOx. Link to comment Share on other sites More sharing options...
jpdriver1 Posted April 28, 2014 Author Share Posted April 28, 2014 thanks gogmorgo --- the hi test was put in by mistake -- burning it out as I go along --- update -- EGR & EGR solenoid valve tested per haynes manual -- both correct fuel pressure 28 w/vacuum & 32 w/o Link to comment Share on other sites More sharing options...
cruiser54 Posted April 28, 2014 Share Posted April 28, 2014 On 4/28/2014 at 8:40 PM, jpdriver1 said: thanks gogmorgo --- the hi test was put in by mistake -- burning it out as I go along --- update -- EGR & EGR solenoid valve tested per haynes manual -- both correct fuel pressure 28 w/vacuum & 32 w/o Should be 31 and 39. What brand of stat? I don't like Bosch O2 sensors. NTK is good. Link to comment Share on other sites More sharing options...
jpdriver1 Posted April 29, 2014 Author Share Posted April 29, 2014 autozone duralast changing out the o2 sensor for denso tomorrow Link to comment Share on other sites More sharing options...
