Yoke u-bolts.
All that matters is that the hole spacing be correct. The XJs and MJs all used the same drive shaft u-joints, so the same u-bolt that works with a D35 should work with a D44. I bought some awhile back with the thought of converting my XJ, but I've not done it because I haven't had any reason to drop the drive shaft. I'll have to look, but I think it should work as well on a rear D44 as on a D35.
Dunno if I got the correct ones, but I think the ones I got were listed for a Ford pickup. Most of the auto parts chains have these in the HELP! line, in blister packs, you just have to search for the correct one.
Here is some more pics for ya Dirty...
Here is the HELP section U Bolts I used:
Image Not Found
Here is two shots of the yoke, (With those Ubolts above) I gave you the number for above:
Image Not Found
Image Not Found
CW
i like my straps. i also like being able to fit a ratchet onto the bolts...you can't do that with the u-bolt.
BUT i haven't had any real problems with them yet...i'm sure my opinion will change when/if i do
Ever trip they stretch on me. Bear in mind I'm being a little hard on things, hard enough to twist the splines on the driveshaft.
Thanks for the pics CW, I'll track down the needed parts as soon as I get off me lazy arse.
