Hi i gonna boore my 4.0 engine this weekend but can't find any tolerance?
Gonna use Sealed Power 677AP 0.060 Pistons
Couldn't find anything on their website either
Take the pistons to the machine shop so they can mike them and insure a proper fit. You want 0.0012-0.0013in clearance.
I am planning to Bore it myself... it is a budget build and just want to test if i manage to do it :)
How are you planning to bore it yourself? Do you have a machine shop?
You don't bore engine blocks with a Dremel ...
How about a ridge reamer? :rotf:
I work with milling so i gonna use one of those:  http://www.zayer.com/en/product/movingcolumn/30kc-ar30kcu-ar/7
 and   http://www.bigkaiser.com/finish-dia590.php
He looks to be in Russia or somewhere in Eastern Europe. His shop looks fairly well equipped, as well. Good on him for the do-it-yourself attitude. It looks like that was probably the only way he could do a lot for his MJ there.
The block is bored and honed.
Didn´t find any upper tolerance so i did it tight (0.025-0.035mm) so it will be a really quiet engine or breakdown :)
Thanks for all replies
And i am from Sweden ;)
You probably know this, but be sure to check the end gap on the piston rings when you assemble the engine. Especially with a very tight fit, this could be important.
Yeah i will control the end gap but thanks for the reminder
