Well I did the valve cover upgrade on the tj now we have a big problem or really a question....
I noticed that the transmission was missing the bell housing cover that cover the front of the transmission....
Does one off a 2.5 xj fit on there?
As long as said XJ has a AX4 or AX5, or any Jeep with a 2.5L and AX4/5 combo, it should work.  The NV3550 uses the same bell as the AX15, so that would be a no-go on fitment.  Doesn't make a difference if it's an internal or external slave.  It's just a dust shield.
