Here We Go Again... Just Changed Cps & Got Trouble
I have been having an erratic idle. It got better after some great advice I git here... not "fixed" but tolerable.
I had a VC gasket leaking so I decided to replace it... which meant cleaning out under the VC. (ewwwwwwww - greasy)
Got through, wouldn't crank. turned over fine. Had pressure on the rail, but no fire. A little over 130K miles, prime suspect was CPS. The prevailing opinion is that they last about 120-130K miles so I replaced it after church tonight. Pain in the backside, but I am "blessed" with small hands so I got it done finally.
all that for background: NOW,
I have a hesitation (maybe call it a bog) under throttle. More noticable when revving in Park, but also noticable when driving. Wasn't doing this before.
Any Ideas?
I intend to check for any vacuum lines I offfended while working, but it's all I got, so I brought my troubles here to the experts.
I ran through a couple dozen posts searching for something within the parameters of my recent troubles, but do dice.
Thanks guys,
Rev. Toid
Bog under throttle and irregular idle can be a lot of things, vacuum leak(check the intake manifold, snug up the bolts), fuel pressure, timing. I'm no expert, but those are things you could check before an actual expert replies.
I an borderline neurotic about dirty hands. I love to mechanic but hate grease. A troubling dichotomy but I live with it.
Cranked but not fired. It now fires n runs after the caps replacement.
Good to hear from you maharaja Cruiser - Of the "master list" I have knocked off 1,3,4,5, 7 (tested, but did not overdrill the holes, Sunday night when I replaced the CPS), 8 but I do not feel really good about it, I need to study up the procedure and do it again, 11, and had my local mechanic check out my EGR valve (number 21) he said it was OK.
I'm sure there is some ingrained metaphysical significance to that number. Should work fine.
In biblical numerology 5 is the signifier of grace and 4 is creative miracles. Grace carrying creative miracles.
Sorry... bible nerd, I guess.
Still haven't checked the cps but the problem cleared up with a little driving.
Let me see the verses that you're referring to.
CPSs can be intermittent and/or weak.
To avoid churching up the thread too much:
http://www.amazon.com/Number-Scripture-Publisher-Kregel-Classics/dp/B004UHU0IQ/ref=sr_1_sc_2?s=books&ie=UTF8&qid=1397164641&sr=1-2-spell&keywords=number+in+sipture
This is the book on my shelf that I reference.
More of a topical examination of patterns than exhortation.
My wife is really studied in stuff like this as she really gets into typology and patterns in the OT.
http://www.biblestudy.org/bibleref/meaning-of-numbers-in-bible/1.html
above is a link to another source... to give you an idea.
disclaimer: I do not elevate such subjective material to the level of sound biblical doctrines and the authority of the divinely inspired scriptures.
Rev. Toid
