My 1990 is running very rich. I have changed O2,tps,iac,cts,plugs,wires,rotar,cap and cleaned contacts on coil. I looked up the number on injectors 0280 150 217 made for a jag. Are my injectors causing the problem? I'm new to working on fuel injected all I want is a mixture screw.
Are those 19# injectors?  If not, I'd recommend Dodge Neon injectors (703's).  They're 4-hole and atomize better.  A good upgrade over the stock, Siemens injectors that like to leak in the middle.
Click on the link in my signature and read post 1. Numerous critical sensors share the same crappy ground circuit. Take care to do all that's recommended there first. I have seen just doing that, an oxygen sensor start working when it didn't before.
The previous owner was like 75 yrs old and did not care how it ran as long as it could pull his bass boat. So going over it changing sensors and over neglected parts. Thanks for the help.
I found this. So this would mean less fuel than stock correct?
Part Number* lbs/hr* cc /min* grams /min* PSI BARS* lbs/hr* cc /min* 80%* 95%* Feed* Impedance* Application* n-H
0-280-150-217* 16.0* 168.2* 121* 36.25* 2.5* 17.53* 184.2* 24.6* 29.2* EV1* High Buick v6-3.8l, Jaguar v12-5.3l, v12-6.0l -
