Sleek Posted March 20, 2014 Share Posted March 20, 2014 Was trying to put the original wheel of my tj on 2wd mj but the front hub are too big so i was wondering if anyone ever had that problem and if a 1inch1/2 spacer would fix it? Link to comment Share on other sites More sharing options...
fatboyadams Posted March 20, 2014 Share Posted March 20, 2014 Are you talking about wheels like this? Link to comment Share on other sites More sharing options...
Sleek Posted March 20, 2014 Author Share Posted March 20, 2014 Yes the exact same wheel Link to comment Share on other sites More sharing options...
Incommando Posted March 20, 2014 Share Posted March 20, 2014 yes you need spacers. 1.25" works but you will probably want to do the rear, too, as the front is already wider Link to comment Share on other sites More sharing options...
Sleek Posted March 20, 2014 Author Share Posted March 20, 2014 Great thanks , yes i will put 1,50" spacer on the 4 wheel Link to comment Share on other sites More sharing options...
benjy_26 Posted March 21, 2014 Share Posted March 21, 2014 Or... You COULD just go get yourself a 2WD ZJ front beam and forget the spacers. My local P-N-P lets thos bad boys go for a Benny rotor to rotor. You may even get lucky and find one with the beefier tie rods off of a V8 model. Link to comment Share on other sites More sharing options...
jpnjim Posted March 21, 2014 Share Posted March 21, 2014 I've had these same wheels on my 2wd for years with no spacers or any issues. I just had to remove the center cap from the wheel. I hit the wheel bearing cap with silver paint every year or so when it starts looking cruddy, but that's it. Link to comment Share on other sites More sharing options...
jpnjim Posted March 21, 2014 Share Posted March 21, 2014 ^^no spacer Link to comment Share on other sites More sharing options...
Sleek Posted March 21, 2014 Author Share Posted March 21, 2014 The front hub on mine are too big to go trough the center cap hole Link to comment Share on other sites More sharing options...
Incommando Posted March 21, 2014 Share Posted March 21, 2014 On 3/21/2014 at 12:47 PM, benjy_26 said: Or... You COULD just go get yourself a 2WD ZJ front beam and forget the spacers. My local P-N-P lets thos bad boys go for a Benny rotor to rotor. You may even get lucky and find one with the beefier tie rods off of a V8 model. Seems like a ton of work for a minor problem. Trip to PnP..remove front beam axle off of junker yourself on the ground with hand tools...cuss when bolts resist you...pay $100...take it home...remove front beam axle off of original MJ...cuss when bolts resist you...replace with junker front beam...dispose of original beam...hope everything on the junker beam works right because you know that the original one does and the original has the stronger spindle/serviceable bearing versus the somewhat fragile unserviceable unit bearing vs. $85 for a pair of spacers from Morris 4x4 ( $170 to match them all) and some lug nut twisting or getting lucky and your dust caps fit through the center hole... :brows: Link to comment Share on other sites More sharing options...
Rockfrog Posted March 21, 2014 Share Posted March 21, 2014 you need to pop the center cap out ... the little center bit that says jeep on it ... the dust cap will poke through the hole. The hub mounting flange specs have not changed from 84-06 (and even the newer 07-14 jeeps use the same hubcenter diameter and spacing just with a different bolt pattern). where does the hub contact with the wheel? I have a different set of TJ wheels on my MJ ... off a 97 TJ, same deal ... popped the center caps out on the front and all was good. This is only an issue on the 2wd due to the dust cap Link to comment Share on other sites More sharing options...
