ggcnash Posted February 22, 2014 Share Posted February 22, 2014 Hi guys in the middle of replacing my axle seals when I was cleaning axle tubes white sealant in front of axle seal came off may be a gasket? Looks like overflow from axle tube sealant is this necessary should I worry about it a pic I pulled off the net shows it in front of the seal just wondering about to go back together with it please help thanks Link to comment Share on other sites More sharing options...
ggcnash Posted February 22, 2014 Author Share Posted February 22, 2014 Just hoping its not some kind of bearing seat disregard the writing in the pic if you can see the white ring rubber like sealant gasket is what I'm referring to Link to comment Share on other sites More sharing options...
ggcnash Posted February 23, 2014 Author Share Posted February 23, 2014 Bump surely one of the gurus got an answer Link to comment Share on other sites More sharing options...
comanchedude Posted February 23, 2014 Share Posted February 23, 2014 yes when you install the seal there is a bead of sealent used and it will leave a small bead after you install the new seal Link to comment Share on other sites More sharing options...
MJRemi Posted February 23, 2014 Share Posted February 23, 2014 I've only re-sealed axles on a AMC20 and did not have to seal anything inside the differential. The fluid should be able to reach the axle shafts and the seal on the hub end keeps it all inside the axle tubing. Yours may be different but I doubt it. Link to comment Share on other sites More sharing options...
ggcnash Posted February 23, 2014 Author Share Posted February 23, 2014 yes when you install the seal there is a bead of sealent used and it will leave a small bead after you install the new seal There is no bead of sealant used in any methods I've read you just grease the seal for easier installation this is in a 99 dana 30 the bead I'm referring to doest even touch the the actual axle seal it's at the end of the axle tube Link to comment Share on other sites More sharing options...
ggcnash Posted February 23, 2014 Author Share Posted February 23, 2014 Bump Link to comment Share on other sites More sharing options...
juan Posted February 23, 2014 Share Posted February 23, 2014 I have done this job twice on D30 and once in a d44 and I have not seen any type of seal applied at this area. It could be some residue from the old seal. clean the area good, make sure the new seal has a nice area to go into and drive it in, if you do not do it right you won't be able to install back up the carrier / gears. bearings and shims. The seal must be driven all the way in but be careful because they like to go in crooked and if it does you will ruin it. good luck. Link to comment Share on other sites More sharing options...
ggcnash Posted February 23, 2014 Author Share Posted February 23, 2014 I have done this job twice on D30 and once in a d44 and I have not seen any type of seal applied at this area. It could be some residue from the old seal. clean the area good, make sure the new seal has a nice area to go into and drive it in, if you do not do it right you won't be able to install back up the carrier / gears. bearings and shims. The seal must be driven all the way in but be careful because they like to go in crooked and if it does you will ruin it. good luck. Thanks I went back together with it they did start crooked a couple of times but I beat them back out and started over hopefully this didn't ruin them didn't see any damage oh well hoping for the best the seal I was referring to was already there it almost looks like overflow rtv from the the axle tube oh well hoping for the best thanks again Link to comment Share on other sites More sharing options...
