Axle Swap
I got to looking at a set of Caddy El Dorado rims I have. Wonder if any one doing a axle swap where the axle is wider than the D30-35 ones are has already tried it. The mounting surface is approx 6-8 inches farther out than a Jeep rim. Bolt pattern is 5 on 5. Depending on lift would require some wheel well trimming. Oldsmobile Toronado would probably be similiar. Just a thought.
