I have done my research before asking you guys on this but I can't seem to put my finger on what the issue is.
Latly only at idle after coming to a stop, the rpm's would go really low and want to stale then jump back up a little.
Today the same thing happened but worse and there was a little hesitation on take off. But after gaining speed I am totally fine. Shifts fine and cruises fine at all speeds.
SO I was thinking either a vaccum leak ( I have checked the hoses but who knows)
or a O2 sensor going bad
or the MAT sensor is going bad (engine temperature sensor that determines air-fuel ratio
I do have a small intake/exhaust manifold gasket leak but I don't see how that would create such a hesitation. I had the gasket go about two years ago and was running fine.
I have upgraded all my grounds, I have a mopar CPS and drilled out the top mounting hole, cleaned all connectors and relays, plugs and distributor are fine, air filter is fine.
I would appreciate the input.
No I have not. If i spray that near the gasket then the motor should stall?
No the motor should accelerate when propane or carb cleaner is sprayed near a vacuum leak due to being more explosive than O2. It is hard to tell when the truck has a rough idle.
yup, the motor will get a bump in rpms if a highly flammable substance is sucked in through a vacuum leak.  :thumbsup:
