willi2ds Posted February 9, 2014 Posted February 9, 2014 So my steering column has the usual GM tilt wobble, so instead of just going in and tightening it. I thought it would be a chance to swap to a column shifter (future auto swap coming in the future). I can't seem to find one locally and any others I can find are very $$$$$$. I've been researching and can't get a definitive answer on if any other GM columns will swap or if I can mix n match parts. Does anyone have any experience with a swap like this or to a link maybe. Thanks
jimoshel Posted February 9, 2014 Posted February 9, 2014 Are you looking for a Jeep specific column or a GM? I have done a couple GM columns into Jeeps, and others, but always with a standard tran. Never done an auto. I have a '87 MJ with a auto trans and column shift and I have a couple GM columns out. I can take some pics, and measurements if you want.
willi2ds Posted February 9, 2014 Author Posted February 9, 2014 What mods did you have to do on the ones you've done?
Crash Posted February 9, 2014 Posted February 9, 2014 Any older GM style column should work. Any modifications will be minor.
carnuck Posted February 12, 2014 Posted February 12, 2014 The Comanche auto column is different because it is a cable shift.
