I have a 1986 jeep comanche 2.5l that i recently replaced the engine in.  Before i replaced the engine the trans leaked and it did afterwards aswell...i replaced the shaft seal on the front and it still leaks.  Has anyone else had this problem and if so how did you fix it.  I would love to get it to stop leaking trans fluid cause I'm always worried about it
Thanks guys
Is the motor running with a weird RPM related vibe? When the torque converter goes bad they will do that. The 9XX neck cracks and causes a vibe and gets worse very quickly. If it doesn't, then it's probably just the front seal.
