Comanche_Fanatic Posted December 31, 2013 Share Posted December 31, 2013 I have an '88 Pioneer 4.0 4x4 BA10/5 D35 I just got an '96 AX15(external) yesterday, along with clutch/flywheel/salve cylinder/etc, it has 23 splines output shaft. it came off an '96 XJ 4x4 4.0L. I know i will be getting a few more parts for the transmission swap. my current tcase is the 231 with the BA10 is a 21 spline, so I'm looking for a replacement tcase. I'm a fan of the 249 so I'm researching as much as I can about this, its hard so far cause most go the other direction. I am not 100% sure it will bolt onto the AX15 perfectly, and if I have to swap out/shorten driveshafts. if i have to lengthen the rear driveshaft by 1" i will look into a D45 rear to compensate for that. and will some disassembly be required between the 231/249 to fit right? Yes I am aware I will have to replace the front axle as well to eliminate the vacuum system. I am gathering as much info so I can order parts in advance and reserve a few days for this swap project. all i want is a confirmation that the 249 will bolt onto the AX15(23spline/external), if so, what year 249 is required for a '96 AX15? as far as I've read is that some ZJ models swapping from 249 to 231, and doesnt require changing out driveshafts. some dis-assembly is done tho. and some people have mentioned that the year of the tcase makes a world of difference. any info would be very helpful, please stay on topic as well. thanks in advance! Link to comment Share on other sites More sharing options...
Mattwheels Posted January 1, 2014 Share Posted January 1, 2014 You could keep the 231 easily by switching the input gear on the 231 with the input gear of the 249, I'm actually doing this myself picking up a used 249 for the input gear alone. and you can eliminate the vacuum system right now by bypassing it. Cruiser Just gave me this link not more than a couple hours ago. http://www.cherokeeforum.com/f51/free-d30-cad-bypass-91-a-38629/ do this retain the D30 save some money and make life easy Also all 249's are 23 spline so even a cracked 249 you pick up cheap would work. although, You might need to find a 249 from 94+ This is a great website for information http://www.novak-adapt.com/knowledge/np_nvg_input_gears.htm Link to comment Share on other sites More sharing options...
mvusse Posted January 1, 2014 Share Posted January 1, 2014 The reason most people go the other direction is because the 249 uses a viscous coupling that WILL eventually go bad. Fact of life, no viscous coupling will live forever. This part is $1300 from the dealership, or $500 from Quadratec. A 231 transfer case can be had for $100 or less. (I picked one up for a buddy a couple of months back for $50) If you want AWD capability, a 242 can be had for the same. (I paid $50 for one with a hack-n-tap SYE started but not finished) Link to comment Share on other sites More sharing options...
Comanche_Fanatic Posted January 1, 2014 Author Share Posted January 1, 2014 You could keep the 231 easily by switching the input gear on the 231 with the input gear of the 249, I'm actually doing this myself picking up a used 249 for the input gear alone. and you can eliminate the vacuum system right now by bypassing it. Cruiser Just gave me this link not more than a couple hours ago. http://www.cherokeeforum.com/f51/free-d30-cad-bypass-91-a-38629/ do this retain the D30 save some money and make life easy Also all 249's are 23 spline so even a cracked 249 you pick up cheap would work. although, You might need to find a 249 from 94+ This is a great website for information http://www.novak-adapt.com/knowledge/np_nvg_input_gears.htm you rock dude, so I will need a 249 short input to pair with the ax15, and a bypass to top it off. The reason most people go the other direction is because the 249 uses a viscous coupling that WILL eventually go bad. Fact of life, no viscous coupling will live forever. This part is $1300 from the dealership, or $500 from Quadratec. A 231 transfer case can be had for $100 or less. (I picked one up for a buddy a couple of months back for $50) If you want AWD capability, a 242 can be had for the same. (I paid $50 for one with a hack-n-tap SYE started but not finished) yes i am aware of the VC that will go bad, I don't drive my Jeep that much and will be relocating within 3 miles of my job. I had considered the 242 but the 4-full time isnt the same as the 249 since theres no limited slip and less power to the front from park. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted January 1, 2014 Share Posted January 1, 2014 Actually, there is equal power from front to rear with both cases, and it is evenly displaced except when a wheel slips. A 242 basically has a differential with planetary assembly inside. It is stronger, more reliable, less prone to failure. Link to comment Share on other sites More sharing options...
