Rohls Posted December 16, 2013 Share Posted December 16, 2013 I have a 92 Manche, and it seems to have little plugs for bulbs under the dash, and I even remember they have 12V going to them. I was reading in a nother thread how to hook these up via the door-jam switch....anyone know where I could find this post here? I've looked with no avail. Thanks. :cheers: Link to comment Share on other sites More sharing options...
Keyav8r Posted December 16, 2013 Share Posted December 16, 2013 Don't know where the post is but you can get the under dash lights from an XJ at the P&P. There is one screw that holds the metal bracket to the dash and a connector to fit the one under your dash. They should work off the door jamb switches and the headlight switch just as the B pillar lights do. I have a set to install in my 91 (probably after the holidays) and may have a spare set if you can't find any near you. Link to comment Share on other sites More sharing options...
johnj92131 Posted December 16, 2013 Share Posted December 16, 2013 Just find a Cherokee in the junk yard with these under the dash lights. Then just plug them in and mount them. Everything you need is there. Link to comment Share on other sites More sharing options...
Minuit Posted December 16, 2013 Share Posted December 16, 2013 What sort of Cherokee would one be looking for? Were they a common option? Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 16, 2013 Share Posted December 16, 2013 For a 1991 one would be looking for a 91 and up XJ (or MJ) for PnP, same connector. If you don't mind cut and splice 1990 and below works fine too. Link to comment Share on other sites More sharing options...
Keyav8r Posted December 19, 2013 Share Posted December 19, 2013 Hmmmm. Don't remember what year XJs I pulled the under dash lights from. I'll have to do a comparison between the 88 and the 91 to see which ones I have. Pulled them every time I saw them at P&P for a while so I may have some from both eras. And, I have a supply of insulated connectors if I need to cut and splice Link to comment Share on other sites More sharing options...
