54bobby Posted December 14, 2013 Share Posted December 14, 2013 guys, on my 87 2.5 the dash lights work but don't dim. they go straight to off when I turn the headlamp switch. also the heater panel lights aren't working. it's not the buld cause every once in a while they will come on then right off again. are the 2 tied into each other? is there a separate fuse for the dimmer? Link to comment Share on other sites More sharing options...
kq.echo.413 Posted December 14, 2013 Share Posted December 14, 2013 change the headlight switch brother Link to comment Share on other sites More sharing options...
54bobby Posted December 14, 2013 Author Share Posted December 14, 2013 dimmer switch or headlamp switch? Link to comment Share on other sites More sharing options...
kq.echo.413 Posted December 14, 2013 Share Posted December 14, 2013 the head light and dimmer in my truck are the same switch..you pull on the headlights and turn the knob right to left to dim.and spray contact cleaner on the harness plug while its out Link to comment Share on other sites More sharing options...
54bobby Posted December 14, 2013 Author Share Posted December 14, 2013 rock auto has both a head lamp switch and a dimmer switch listed. I was just wondering which one? are they one in the same. they have different pt#'s Link to comment Share on other sites More sharing options...
Oyaji Posted December 14, 2013 Share Posted December 14, 2013 the head light and dimmer in my truck are the same switch..you pull on the headlights and turn the knob right to left to dim.and spray contact cleaner on the harness plug while its out ^^^ This - but you need to get the contact cleaner INSIDE the switch to clean the dash dimmer potentiometer. If contact cleaner doesn't do the job, then replace the headlight switch. Link to comment Share on other sites More sharing options...
Keyav8r Posted December 14, 2013 Share Posted December 14, 2013 The dimmer for the dash lights is built into the headlight switch. As said above, you pull the knob out to turn on parking lights (first step) then further out to turn on the headlights. Rotating the knob operates a rheostat that is built into the switch which dims or brightens the dash lights, depending on which way you turn it. If turned fully to the left, it should turn on the cab courtesy lights (B pillar lights and under dash lights). If you don't have the under dash lights, go to your local P&P and pull a set from a Cherokee. One screw holds the bracket to the dash and then disconnect the connector. Your truck should have the connectors behind the dash. Sorry, got a little off topic there. The separate dimmer switch advertised is probably the low beam/high beam switch for the head lights. Link to comment Share on other sites More sharing options...
carnuck Posted December 18, 2013 Share Posted December 18, 2013 The other dimmer is the headlight dimmer hi/lo switch. Link to comment Share on other sites More sharing options...
