Heat/ac Question 89 Mj 4.0
I've been having some issues with the heat in my MJ. It seems like I'm getting very little air out of all the vents even on high. My defrost vents blow like crazy on cold but don't flow nearly as well on hot.
I jammed my arm up behind the heater box and can feel that there is a decent amount of air coming out back there even on the defrost setting. Is this supposed to happen? I can't tell if there is a vent back there or not.
I also have a substantial vacuum leak on my intake. I am able to switch between air settings still but it usually reverts back to defrost eventually when driving. Is there a vacuum controlled blend door that might not be opening all the way and in turn causing poor airflow?
