Bounty Hunter Posted August 24, 2005 Share Posted August 24, 2005 I noticed several members have mentioned swapping in a non-disconnect D30 into the front of their MJ's. What's everybody have against the disco axle? I prefer the disco axle, not only is it high pinion, but the CAD allows one to manually disconnect the pass. side axleshaft, a great combination with a front locker. I run a Lincoln Locker in the front and it's completely invisible on the road, it's my poor-man's selectable locker :lol: Can't beat the traction offroad. Link to comment Share on other sites More sharing options...
Pete M Posted August 24, 2005 Share Posted August 24, 2005 Not only is it just-one-more-thing-to-break, but they have the smaller U-joints. Upgrading to the later model shafts allows use of the Dana 44 size joints. But if yours works for you, then there's certainly no need to change anything. Jeep on! --Pete Link to comment Share on other sites More sharing options...
Bounty Hunter Posted August 24, 2005 Author Share Posted August 24, 2005 '95 YJ disconnects are the larger 297x ujoint similar to the 44, it's what I have in my YJ. The disconnect splines are monsterous, so no weakness there. Link to comment Share on other sites More sharing options...
Pete M Posted August 24, 2005 Share Posted August 24, 2005 I don't necessarily mean the shafts themselves would break, but the mechanism that shifts them has caused countless headaches for MJ/XJ owners over the years. The biggest issue is most certainly a lack of maintenance on our almost 20 year old Jeeps, but it's a fact of life that most owners don't think about axle lube and vacuum lines until it's too late. 95 YJ shafts are a good upgrade, but finding one in the junkyards can seem impossible, where-as solid shafted XJs are everywhere. Aftermarket shafts exist, but if the owner can afford them, they might as well just get a regular locker. I don't know about everyone else, but when I recommend the solid shaft conversion, my intent is making the owner's life easier as well as making the truck stronger. Jeep on! --Pete Link to comment Share on other sites More sharing options...
Bounty Hunter Posted August 24, 2005 Author Share Posted August 24, 2005 I know where you're coming from, the same CAD is used on all YJ's. You have to really know how to troubleshoot the system to keep it functioning properly, unless you convert to a cable. Then it's a cheap way to spool the front for the ultimate in traction and reliability. Link to comment Share on other sites More sharing options...
matt89mj Posted August 24, 2005 Share Posted August 24, 2005 The only complaint I have with the disconnect on the YJ is that sometimes it won't come out. It only happens once in a while but on occasion I have to pull the vacuum lines and that will let it come out. I agree tho that it is a good axle, if you upgrade to the bigger 297x u joints. It would allow for a Lock right or a spool up front with no adverse affects for on street driving unlike the non- disconnect axle. The only way to put a spool there is the $1000 manual hub conversion. And unless you have no choice, that is WAY too much money. The only reason I am putting a non disco axle in my MJ is because I already have it and don't want to go searching for one. :D That and it is being converted to 4wd. If it had the disco axle in there I would just put the cable select in there and be done, with the 297x upgrade at the same time of course. Matt Link to comment Share on other sites More sharing options...
bigwormskidoo Posted September 5, 2005 Share Posted September 5, 2005 i couldnt stand my disconnect it was always popping out and in of lock i hated that axle Link to comment Share on other sites More sharing options...
Jax MJ Luvr Posted September 6, 2005 Share Posted September 6, 2005 so true, my friend Richard versed me on all the benefits of the straight axle d30 as opposed to the disconnect version... one less thing to worry about and 4 less vaccuum hoses to hook up and look after ;) no muss no fuss Link to comment Share on other sites More sharing options...
