RochesterMJ Posted November 18, 2013 Posted November 18, 2013 I've got manual windows and when I roll the drivers window down the "weatherstrip Glass Inner Seal" (#2 in the pic) tends to fold over and I have to push down on the glass while cranking to get the window all the way down. I've tried the dry silicone spray (temporarily helps), tried trimming them back (didn't help, looked like crud), and replaced them with seals from the JY that looked like they had more flocking (the fuzzy part) (no change). Its been like this for a while but I can't remember if its always been like this, I've had the trim panels off a couple times, did I mess something up when I reinstalled them? Is there a way to adjust the seal away from the glass or tilt it so its not pressing against the glass as hard?
jeepsouth Posted November 18, 2013 Posted November 18, 2013 I too have this problem ,and would be very interested to know how to correct it.
gogmorgo Posted November 18, 2013 Posted November 18, 2013 When I put my door panels back on once, they were weird at the top so I pulled them back off and noticed that I forgot to clip them back into the thing at the bottom of the window. Could that be your problem?
jeepsouth Posted November 19, 2013 Posted November 19, 2013 Just found my build sheet behind the drivers side door panel! It's in pristine condition too.
RochesterMJ Posted November 19, 2013 Author Posted November 19, 2013 Checked the seals and they're installed correctly. Figure its either worn out or when I had it off I might have bent the metal carrier and its now pushing the seal into the glass too much. Will have to experiment next time I pull the door panel off - don't care enough to mess with it in the cold
