TMW Posted November 13, 2013 Share Posted November 13, 2013 i have a 87 4.0 auto 4x4. i just got it. the po ran it outta fuel and now it want start back up after putting a few gallons in. it has pressure at the rail, has spark. if i pour gas in the tb it will start but run rough and only run til what i poured in is used. any ideas on what to check. thanks you Link to comment Share on other sites More sharing options...
cruiser54 Posted November 13, 2013 Share Posted November 13, 2013 You may have fuel at the rail, but not enough of it and not at high enough pressure. I'll bet the fuel pump is dying. Link to comment Share on other sites More sharing options...
Keyav8r Posted November 13, 2013 Share Posted November 13, 2013 Did you bleed the air off the rail? You can use an air conditioning hose fitting on the Schraeder valve on the rail. Have a container ready to collect any fuel that comes out. I bought an adapter fitting to go from the female thread Schraeder hose fitting to 1/4" pipe threads to connect a pressure gauge and test the fuel pump pressure. You'll need a good quality gauge that reads at least 60 PSI as you want the somewhere near mid-range on the gauge scale. Gauges are more accurate at mid-range than near either end of the range. You can find the fitting at most large HVAC supply distributors. I got mine at Johnstone Supply. Link to comment Share on other sites More sharing options...
TMW Posted November 13, 2013 Author Share Posted November 13, 2013 ok thanks i will do this and report Link to comment Share on other sites More sharing options...
TMW Posted November 14, 2013 Author Share Posted November 14, 2013 i just wiggled some wires under the intake and she fired up and runs good...time to clean all connections...lol Link to comment Share on other sites More sharing options...
gogmorgo Posted November 14, 2013 Share Posted November 14, 2013 Make sure those wires aren't contacting the exhaust manifold which is also right under the intake. If they do, the exhaust heat will melt the insulation and they'll short out. Link to comment Share on other sites More sharing options...
TMW Posted November 14, 2013 Author Share Posted November 14, 2013 will do Link to comment Share on other sites More sharing options...
