johnj92131 Posted November 11, 2013 Posted November 11, 2013 Has anyone seen a "police" full gauge cluster for a column shifter automatic? I currently have 3 regular full gauge clusters for 91+ XJ/MJ I have a cluster with the big fuel gauge, 3 small gauges and a 115 mph calibrated spedometer for the 91+ Also have a big fuel gauge, 3 small gauge, regular speedo with AMC logo in the 4th small gauge for the 90< And finally, in my truck I have the big fuel gauge with column shift automatic base cluster. Looking to build a bastard cluster around the 115 calibrated speedometer. Question, did the factory produce a tach face without the red paint I see on my 3 late full guage clusters? I suspect I need to look at Ebay.UK to find what I want. Yes, I have purchased some files from GoJeep for custom gauges, but that was before I found the "police" calibrated 115 mph cluster, Know I can mix and match small gauge face plates to get the look I want, but what will be compatible with the 115 mph speedometer? Think I need the printed circuit on the back of the cluster, IF it ever existed. Realize I may be over thinking this whole thing. But I can be very anal at times. This is one of those times. Oh, BTW, I have read and bookmarked most of the cluster swap discussions here. Just for what it may be worth. Doesn't mean I understood them all.
Automan2164 Posted November 11, 2013 Posted November 11, 2013 I don't think the full cluster blue faced gauges were available in the HO years. You would have to use a full cluster housing with the correct foil back. Then maybe see about swapping in all blue faced gauges... Only problem I could forsee is the difference in required voltages for the fuel gauge and possibly one or two others. That, and pin location for the new/old gauges. Rob
TheDude Posted November 11, 2013 Posted November 11, 2013 Send my friend an email on his site. He can make you any kind of cover you'd want! http://www.azzysdesignworks.com/
jpdriver1 Posted November 13, 2013 Posted November 13, 2013 Send my friend an email on his site. He can make you any kind of cover you'd want! http://www.azzysdesignworks.com/ I have a set of his guage faces on snydley, they are great in low light conditions
johnj92131 Posted November 16, 2013 Author Posted November 16, 2013 I don't think the full cluster blue faced gauges were available in the HO years. You would have to use a full cluster housing with the correct foil back. Then maybe see about swapping in all blue faced gauges... Only problem I could forsee is the difference in required voltages for the fuel gauge and possibly one or two others. That, and pin location for the new/old gauges. Rob Was there a Renix era blue face full gauge cluster? Think gauge faces can be used on HO clusters. That is why I ask about a blue face full cluster. Thanks,
Automan2164 Posted November 16, 2013 Posted November 16, 2013 Yes. I think through '90. More prevalent in the earlier years. The Diesel has one... But the 4.0L is the same, minus the boost gauge. Rob
Crash Posted November 17, 2013 Posted November 17, 2013 Yes, Some renix had blue gauge cluster. I have one from my MJ. IS the speedo you have the one that the 115 is where the 85 would be? Or 115 at the bottom?
johnj92131 Posted November 17, 2013 Author Posted November 17, 2013 115 is at the bottom. Like in this picture: http://comancheclub.com/topic/22007-fs-random-crap-ilwi-border/?hl=cluster
