HughMann Posted November 2, 2013 Share Posted November 2, 2013 for swapping a xj waggy grill(4 lights) onto the MJ what all do I need other than the grill and bezels and possibly the headlight buckets? Link to comment Share on other sites More sharing options...
MtnClimber Posted November 2, 2013 Share Posted November 2, 2013 You'll probably need the headlight/blinker wiring harness. I believe the wiring harness connector is near the airbox/radiator support. You'll want all the light assemblies too. Link to comment Share on other sites More sharing options...
relyt120 Posted November 2, 2013 Share Posted November 2, 2013 you need the whole headerpanel assembly and all wiring bezels grill, everything Link to comment Share on other sites More sharing options...
dasbulliwagen Posted November 2, 2013 Share Posted November 2, 2013 Depending on the year of your donor you may have to change how it mounts. My donor was an 86. In 86 the mount studs are on the header. In 87 they changed to being on the body. The lower ones were in the same position but the uppers weren't. I removed the studs from the fender and drilled new holes to mount the header. The wiring for the lights was plug and play. Link to comment Share on other sites More sharing options...
