carnuck Posted November 7, 2013 Posted November 7, 2013 They aren't "legally" available as such, but a Chev Fuel pump block off plate needs only minor mods to fit the 2.5L TBI's EGR opening.
Oyaji Posted November 7, 2013 Posted November 7, 2013 They aren't "legally" available as such, but a Chev Fuel pump block off plate needs only minor mods to fit the 2.5L TBI's EGR opening. Good to know - thanks... although since aluminum cuts like butter, it didn't take me but a few minutes to make one. Here is another trick: to block off the EGR source port, heat an old copper penny (1970s or earlier are copper, after that they are plated zinc and will easily melt) red-hot, then drop it into cold water to anneal (soften) it. Drop it into the port on the manifold, then screw in a flange nut salvaged from an EGR pipe and snug it down good. Works great. :)
mdwatson Posted November 8, 2013 Author Posted November 8, 2013 Yes, I did as Oyaji said and I made a EGR port blocking plate out of aluminum that I had laying around. It covered both holes.
