54bobby Posted October 9, 2013 Share Posted October 9, 2013 so guys, whats the fix for a window handle knob that has come off? what do you guys use to reattach the knob so it still spins while cranking the window up? Link to comment Share on other sites More sharing options...
Eagle Posted October 9, 2013 Share Posted October 9, 2013 so guys, whats the fix for a window handle knob that has come off? what do you guys use to reattach the knob so it still spins while cranking the window up? A window handle from the rear door of a 4-door Cherokee. Link to comment Share on other sites More sharing options...
54bobby Posted October 9, 2013 Author Share Posted October 9, 2013 wanting to color match. what year xj's also came in cordovan (maroon)? Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted October 10, 2013 Share Posted October 10, 2013 so guys, whats the fix for a window handle knob that has come off? what do you guys use to reattach the knob so it still spins while cranking the window up? A window handle from the rear door of a 4-door Cherokee. Why do you specify the rear? I pulled 3 off of a '96 XJ (two front ones and one rear one). All 3 are exactly the same. :dunno: Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 10, 2013 Share Posted October 10, 2013 so guys, whats the fix for a window handle knob that has come off? what do you guys use to reattach the knob so it still spins while cranking the window up? Best fix? Install power windows. Link to comment Share on other sites More sharing options...
Eagle Posted October 10, 2013 Share Posted October 10, 2013 Why do you specify the rear? I pulled 3 off of a '96 XJ (two front ones and one rear one). All 3 are exactly the same. :dunno: I specified the rear because my experience is that the front windows get used a lot more, so they are usually not worth bothering with. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted October 10, 2013 Share Posted October 10, 2013 Why do you specify the rear? I pulled 3 off of a '96 XJ (two front ones and one rear one). All 3 are exactly the same. :dunno: I specified the rear because my experience is that the front windows get used a lot more, so they are usually not worth bothering with. That makes sense. I wasn't thinking about that. :doh: Link to comment Share on other sites More sharing options...
