AeroNautical Posted October 6, 2013 Share Posted October 6, 2013 I've searched around the web a bit trying to find out how to thoroughly clean a differential and axle tubes. I've read brake cleaner works well, I've also read putting your garden hose on one side and filling it until it pours out the other is a good way to get out debris and other nasties. Honestly, I'm a bit skeptical when it comes to putting water where it shouldn't be. How do you guys recommend cleaning up the diff? On a side note: I didn't want to make a new post for this, but I removed my axle shafts and found a startling scorch mark on one of my axles. It doesn't look too bad, but what do you guys make of it? Link to comment Share on other sites More sharing options...
sloride Posted October 6, 2013 Share Posted October 6, 2013 This stuff is bio friendly and cleans up with water. I'd use super clean, a brush, a hose and finish with a heaping helping of WD-40 (Water Dissipater-40) http://www.amazon.com/SUPER-CLEAN-DEGREASER-GALLON/dp/B000CCM63K Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted October 6, 2013 Share Posted October 6, 2013 :agree: That's what I use too for pretty much everything grease, oil and grime related on the Jeeps. Link to comment Share on other sites More sharing options...
AeroNautical Posted October 6, 2013 Author Share Posted October 6, 2013 Really? I'm surprised that stuff wouldn't be too tough on the seals, thanks for the advice. Any idea on that axle shaft before I put it back in? Edit: It looks bent in the photo, but thats an illusion. It's straight, just got that scorch mark. Link to comment Share on other sites More sharing options...
sloride Posted October 6, 2013 Share Posted October 6, 2013 I was under the assumption you had the diff down to bare bones. Using Super Clean with the seals in place might not be a good idea....... Are you talking bearing scorch marks? Is there a ridge in the shaft from the bearing race? Have you checked shaft diameter, bearing surface to non bearing surface? Link to comment Share on other sites More sharing options...
Automan2164 Posted October 6, 2013 Share Posted October 6, 2013 Might as well do the seals if you have everything else out. Rob Link to comment Share on other sites More sharing options...
Eagle Posted October 6, 2013 Share Posted October 6, 2013 Why would you take the axle down that far to clean it out, and NOT replace the seals? False economy. Link to comment Share on other sites More sharing options...
AeroNautical Posted October 6, 2013 Author Share Posted October 6, 2013 I tore it down to install disc brakes, but I figured I would clean it while it was stripped. The scorch is about a quarter way up the shaft, well away from the bearings. It just seems like a machining error from the factory the closer I look at it. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted October 6, 2013 Share Posted October 6, 2013 I, too, would advise replacing the seals. It's one of those "while you're there" things and it would be a good peace of mind thing to me. But yea, SuperClean would be fine for everything but the seals... Link to comment Share on other sites More sharing options...
AeroNautical Posted October 6, 2013 Author Share Posted October 6, 2013 I understand it's a smart thing to do, but the seals on there now have MAYBE 1000 miles on em, wanted to save myself some work and money. Link to comment Share on other sites More sharing options...
Alexia Posted October 6, 2013 Share Posted October 6, 2013 If the axle was entirely stripped of every part, out of the vehicle, and able to be stood up on end then I would run a soapy water mix through it. Only because it could be stood up on end to drain it properly. The only reason I did not do the axle seals on the D44 is because they are pressed on to the axle shaft. One ended up leaking and I have to get it replaced anyway. Link to comment Share on other sites More sharing options...
