boardmanMJ Posted October 5, 2013 Share Posted October 5, 2013 I have been reading some write ups on jeep forum and Cherokee forum and they said that it's possible to swap ford 5.0l injectors onto the jeep 4.0l. I was browsing the clearance section at the local summit racing equipment and I came across a bag of 8 remanufactured injectors for the 5.0 for $25. I couldn't pass it up so I grabbed them and tried to swap them in. The plugs aren't even close to being correct. I have no idea what year the injectors are off of they just said 5.0l injectors. I also read that you can swap in mid 90s era stratus injectors but would they work on my 00 XJ? Any help would be appreciated. Link to comment Share on other sites More sharing options...
Alexia Posted October 5, 2013 Share Posted October 5, 2013 2000 XJ uses EV6 connectors. Those injectors probably have EV1 connectors. Hence, these adapters. http://www.ebay.com/itm/LS2-LS3-to-LS1-Injector-Fuel-Injector-Adapters-set-of-8-EV6-EV1-/190891205172?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c7200a234&vxp=mtr Can you get us the part numbers off the sides of the injectors? That will tell us more about them. Link to comment Share on other sites More sharing options...
Eagle Posted October 5, 2013 Share Posted October 5, 2013 The 5.0L Ford injectors are used as replacements for the Renix 4.0L Jeeps. They don't flow enough for the HOs and post-HOs. Link to comment Share on other sites More sharing options...
yxmj Posted October 6, 2013 Share Posted October 6, 2013 You will be wanting the 4 nozzle injectors from a dodge neon google it ( if i remember right the good ones have a 73 in the part number.....google it cuz i am not positive) Here I found it ( it was 703 not 73) http://www.jeep4x4center.com/blog/?p=1051 Link to comment Share on other sites More sharing options...
boardmanMJ Posted October 7, 2013 Author Share Posted October 7, 2013 Thanks for the help everyone! I see that I could also use mid 90s dodge stratus' (from a few other write ups I read) but all the write ups seem to be for the pre 2000-01 4.0l. I also read that the injectors have to be our of a 2.4l engine in order for them to flow right. Would these injectors work with my 00 XJ motor? Sorry for the stupid questions. Found out the information I needed on NAXJA I need the 784 injectors off 98+ 2.4l motors for my 00. Thanks! Link to comment Share on other sites More sharing options...
