Eagle Posted September 30, 2013 Share Posted September 30, 2013 For those of us who still have drum brakes on the rear, I'm sure you all know that drums are a lot more expensive than rotors, and drums for a Dana 44 are almost impossible to find. For the most part, when doing a brake job I've found that the working part of the drums don't need anything, but there's a lip of rust at the open edge that screws things up. It's also difficult to find a shop with a brake lathe these days, it's expensive when you do find one, and they don't listen when you tell them to ONLY cut that rust ridge down to fluch with the rest of the drum, not to cut the actual braking surface. So ... for the dedicated do-it-yourselfers who don't happen to own a brake lathe or a machine shop ... does anyone have any good ideas as to how to remove that ridge when doing a brake job? Link to comment Share on other sites More sharing options...
jimoshel Posted September 30, 2013 Share Posted September 30, 2013 I've used both a small grinding stone and a rotary file in a 3/8 hand drill. Clamp the drum down solid and set something up where you can rest your hand on to steady the drill. Don't get in a hurry. A pain in the butt but it gets the job done. Link to comment Share on other sites More sharing options...
sloride Posted September 30, 2013 Share Posted September 30, 2013 Any machine shop should be able to use an engine lathe to chuck up a hub and face that ridge off. Link to comment Share on other sites More sharing options...
Eagle Posted September 30, 2013 Author Share Posted September 30, 2013 Any machine shop should be able to use an engine lathe to chuck up a hub and face that ridge off. Sure -- for big bucks. I'm looking for do-it-yourself methods. Link to comment Share on other sites More sharing options...
Oyaji Posted September 30, 2013 Share Posted September 30, 2013 You could bolt the drum on backwards, start the engine, drop it in gear, and use the rear end and drivetrain as a lathe. If you do this, take all safety precautions of course, and use Jim's grinding method. Keeping the drums balanced will be less of an issue with them rotating. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 30, 2013 Share Posted September 30, 2013 When I had drums, I used to use a Dremel tool and rotary stone - very carefully. Easier to control than a big hand drill. Link to comment Share on other sites More sharing options...
Eagle Posted October 1, 2013 Author Share Posted October 1, 2013 You could bolt the drum on backwards, start the engine, drop it in gear, and use the rear end and drivetrain as a lathe. If you do this, take all safety precautions of course, and use Jim's grinding method. Keeping the drums balanced will be less of an issue with them rotating. I was thinking about trying this, as a matter of fact. Link to comment Share on other sites More sharing options...
hassyfoto Posted October 1, 2013 Share Posted October 1, 2013 Like most folks, I use a grinder. Fortunately for me, I have multiple tools for the job. A six inch grinder, a Dremel with multiple attachements, a grinding wheel and some other assortment of grinding tools. It's time consuming, but if you want to spend a little time and a large part of elbow grease, your can accomplish the task yourself. Link to comment Share on other sites More sharing options...
Oyaji Posted October 1, 2013 Share Posted October 1, 2013 You could bolt the drum on backwards, start the engine, drop it in gear, and use the rear end and drivetrain as a lathe. If you do this, take all safety precautions of course, and use Jim's grinding method. Keeping the drums balanced will be less of an issue with them rotating. I was thinking about trying this, as a matter of fact. . You might have to fiddle with the centering a bit - check it on the smooth wear surface of the drum so you don't get out of round grinding down the lip. You won't need much speed - idling engine will do. Try to come up with some blocks to use as a jig/brace to hold your grinder steady, and take care not to get long sleeves or anything else caught, else we may not be hearing from you again! . It goes pretty fast depending on your grinder, so it pays to be slow and deliberate in your work as you go. Link to comment Share on other sites More sharing options...
dave92cherokee Posted October 1, 2013 Share Posted October 1, 2013 In my experience that lip doesn't get to bad and when it does that means the braking surface is worn down past it's tolerances. When it's a small lip during normal maintenance/inspection I usually just use a piece of sand paper and go around it a few times. Then spray it down with brake cleaner to clean off shavings/dust. Link to comment Share on other sites More sharing options...
