Byrdock Posted September 29, 2013 Share Posted September 29, 2013 Does the cooling fan relay on a 88 4.0 use a 5 terminal relay like the fuel pump relay? My plug has 4 wires for the outside terminals, but nothing in the center. The relay is a 4 terminal relay but I can't find any parts places that have one like it. Do I have to go to the dealer for this part? Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 29, 2013 Share Posted September 29, 2013 http://www.rockauto.com/catalog/raframecatalog.php?carcode=1179839&parttype=3060&a=Search%2Bfor%2B1988%2BJEEP%2BCHEROKEE%2BCHIEF%2B4.0L%2B242cid%2BL6%2BMFI%2B%2528M%2529&ck[iD]=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[php_SESSION_ID]=f75r45lbfsoapp3l2v4jnmi096 Link to comment Share on other sites More sharing options...
Byrdock Posted September 30, 2013 Author Share Posted September 30, 2013 Thanks!! I didn't think to check Cherokee parts. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted September 30, 2013 Share Posted September 30, 2013 You can just use a 5-prong relay. They work the exact same. The 4-prong one is just a 5-prong with that center one missing. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 30, 2013 Share Posted September 30, 2013 You can just use a 5-prong relay. They work the exact same. The 4-prong one is just a 5-prong with that center one missing. Sure, if you want to hack off the unused 5th relay pin to fit the 4-pin relay socket. Also the aux fan relay is a 40A relay; the other common 5-pin relays used are only 30A. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted September 30, 2013 Share Posted September 30, 2013 All three of my Renix era XJ's have a 5-prong socket. As far as the 40A thing, I'm not saying you're wrong, however, all three of mine had the stock 4-prong relay installed and all of them were 30A. The stock fan pulls somewhere in the neighborhood of about 23-25 amps IIRC. I don't know what's going on there, but honest to goodness all three have 5-prong sockets. Link to comment Share on other sites More sharing options...
