Wrz Posted September 14, 2013 Share Posted September 14, 2013 Well my jeeps just about complete, and I topped off all the fluid today and when I go to move the jeep I hear a grinding noise conning from the converter area. I tightened all the bolts so its not hitting the flex plate Fluids good and topped off Will roll a couple feet foward or back but as soon as the gas is applied to won't move and the noise comes Trans recently had all new seals down, I did find some dust shavings when I removed the lower flex plate I'd hate to take the trans out if its something simple but I'm leaning towards a bad converter Specs 1990 jeep mj Lwb 4.0 auto 4x4 Any help would be appreciated Link to comment Share on other sites More sharing options...
Blue XJ Posted September 15, 2013 Share Posted September 15, 2013 What kind of grinding noise? Are you sure the tcase linkage is correct and its fully in gear? Link to comment Share on other sites More sharing options...
Wrz Posted September 15, 2013 Author Share Posted September 15, 2013 What kind of grinding noise? Are you sure the tcase linkage is correct and its fully in gear? Sounds like when it's spinning its rubbing on metal, I thought about the linkage, but if it wasn't fully engaged, it shouldn't move forward or back at all right? Ill take a video tomorrow so you can hear the sound, I'm praying at this point I don't have to drop the trans again... Will be a pita Link to comment Share on other sites More sharing options...
carnuck Posted September 17, 2013 Share Posted September 17, 2013 Starter hanging loose? Cracked flexplate? Link to comment Share on other sites More sharing options...
