Red 1989 MJ Posted September 3, 2013 Posted September 3, 2013 Hi, Everybody Long time no write, I am in the process of a motor swap(1989 to 1990). Could any tech wiz help me with the metal fuel line near the intake? I need to disconnect without destroying the quick connect plastic tab? Thanks Éric
Rockfrog Posted September 3, 2013 Posted September 3, 2013 if it's the white plastic tabs I'm thinking it is ... it should just be a squeeze the tabs together and pull affair.
jimoshel Posted September 3, 2013 Posted September 3, 2013 Sometimes the tabs get full of crap and you can't squeeze them. Usually a blast from a air hose will clean it out.
