Hey guys just thought I would start an official build thread since today I bought my first parts for the MJ. I got bit by the bug and now there's no going back.
Today I purchased basic maintence parts
Bosch Plugs and wires
valve cover gasket
Precision Injectors for jeep comanche
This should get her purring like a kitten
Next on the list:
Upgrade headlights to H4's
Replace the 10 pin harness in the upper drivers side fender for the lighting assembly ( figure I can pull one off of an XJ)
Upgrade all grounds
Clean all electrical plugs
Replace battery cables
Was cleaning all my electrical connections today and ended up snapping off a pin on the latch relay. Does anyone know what I can replace it with? Can I just use any 5 pin relay? Should it be 12V or 24V?
1185961_10151614624420924_1333055577_n.j
Also I got these today!
1186831_10151614619805924_1917178457_n.j
Over the weekend I cleaned up the electrical and installed the upgraded injectors. Then went to a pick n pull and got some fun parts.
Everything was half off so I kind of got carried away.
Parts:
Grill
healight trim
RS turn signal
front light harness
Upgraded gauge cluster
Wanted to get more but 4 hours in 98 degree weather with no water tends to get to you.
  • 9 months later...
Wow it's been a really long time since I've been on here. Was pretty consumed by moving and then the car blew up yadda yadda yadda.
Anyways I'm finally back to what I've been wanting to do...Rebuilding the manche
I have her parked in the barn and this will be it's resting place for a few months while I disassemble and  rebuild
10414542_10152170015970924_1891306420238
Removed the bed liner, I'm impress at how good the truck bed looks. now I just need to get some side panels to get it looking good again.
10371488_10152170016195924_8541113094072
Right now I'm working on dropping the fuel tank, removing the truck bed, and gutting the cab. After that I will be grinding the frame rails and putting por15 on them.  After only being able to remove 2 bolts last night I realized I need a torch, larger drill bits, and cutting wheel to get this thing removed. Stay tuned as I continue to rip this guy apart.  :)
Glad I invested in a canister filter.
10300984_10152184770835924_8054599782340
1524870_10152184770785924_54618508821253
Managed to get all the loose paint and rust off with a wire wheel last night and also got the top of the passenger wheel grinded.
1907662_10152184770615924_11633927818751
10322822_10152184770655924_7578664278928
10367810_10152184770910924_7422437147095
  • 4 weeks later...
Got some more work done. I'm basically done with the stripping process. No I just need to actually start spending money.
10389484_10152225291295924_1481003212901
Tested out some rust remover I had laying around. I'm very pleased with the results.
10458101_10152225291380924_7364975016899
Got the bench seat removed. What a mess the previous owner left me.
10502081_10152225632170924_2850864268529
Found out that floorboards literally mean a board for the floor.
10461948_10152225707105924_4329720618042
Looks like I need a welder and some new floor pans.
  • 1 month later...
