ParadiseMJ Posted August 8, 2013 Share Posted August 8, 2013 So, When replacing my head, is it OK to bolt the manifolds to it before putting the head back on. As in, get the thing all torqued in before lining everything up. Seems like it would be easier to install the manifold that way, without being a contortionist for the last nut in the back. Other than the weight, and the bulk of it all, is there any reason NOT to do it this way?? Link to comment Share on other sites More sharing options...
sinkrun Posted August 8, 2013 Share Posted August 8, 2013 I have read on other forums that you can but have not done it. Link to comment Share on other sites More sharing options...
Oyaji Posted August 8, 2013 Share Posted August 8, 2013 Better still, don't remove them in the first place when removing the head ;) I don't recall if this works for this engine, but it does work for others. There is the added benefit of less work for both removal and reassembly, besides not needing new gaskets either. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted August 8, 2013 Author Share Posted August 8, 2013 I thought I'd remove the manifold to replace the gasket anyway. I read that removing the head WITH the manifold was OK, so I surmised that it would be easier to re-install it like that...just a thought. Link to comment Share on other sites More sharing options...
johnnyc Posted August 8, 2013 Share Posted August 8, 2013 Yes! Makes it much easier to install and torque the bolts. I used a cherry picker and an extra pair of hands to lower it into position. Link to comment Share on other sites More sharing options...
cruiser54 Posted August 9, 2013 Share Posted August 9, 2013 It's fine. Take 2 of the long old headbolts, cut the heads off and use them as guides when dropping the head on. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted August 9, 2013 Author Share Posted August 9, 2013 It's fine. Take 2 of the long old headbolts, cut the heads off and use them as guides when dropping the head on. Thanks...I got the new bolts, so I already cut the heads off a few. I wish I hadn't "persuaded" my sons to get out of the house so soon (I mean after all, they were only 23)...I need some muscle. Link to comment Share on other sites More sharing options...
92tanMJ Posted August 10, 2013 Share Posted August 10, 2013 Yes! Makes it much easier to install and torque the bolts. I used a cherry picker and an extra pair of hands to lower it into position. That is exactly what I did. My dad and I lifted it and put it on by hand....and it was a b*@$£. It was just really awkward to get on. Link to comment Share on other sites More sharing options...
