Comanche Specs
hi, yxmj, I have same truck you have, but mine is 4x2, I wanto to change to 4x4, do you know if the cherokee has the same transmission?
Saludos.
You've bumped an old thread. You would be best to post the specs of your MJ. The chances are that it will share driveline components with a like model XJ, and that will be the easiest way to get the needed parts to do a 4wd conversion.
Saludos.
^^^ In fact, thisa thread is three YEARS old. You'll get much better information if you start a new discussion with your question, and include some information about your truck.
Guest
This topic is now closed to further replies.
