1986- - The dipped front cross member and the non-depressed area next to the large oval wire grommet hole gives it away.
Ok, so you're saying that the dipped front cross member is only found in the MJ's with the non-depressed area next to the oval?  The reason I'm asking is because I heard from some users here that some late '86s had the revision for the 4.0 firewall but I didn't know if the front crossmember would be like the '87+ or still like the '86-, ie, both go hand in hand.
