onlyinajeep726 Posted July 20, 2013 Share Posted July 20, 2013 Can anyone tell me by looking at these pictures if this is the typical pre-'87 firewall or if this is the one with the revision for the 4.0? It's hard to tell just by looking. Link to comment Share on other sites More sharing options...
Alexia Posted July 20, 2013 Share Posted July 20, 2013 1986- - The dipped front cross member and the non-depressed area next to the large oval wire grommet hole gives it away. Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 20, 2013 Share Posted July 20, 2013 Excellent Alex. I had no idea since I've never had an 86. :thumbsup: Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted July 20, 2013 Author Share Posted July 20, 2013 1986- - The dipped front cross member and the non-depressed area next to the large oval wire grommet hole gives it away. Ok, so you're saying that the dipped front cross member is only found in the MJ's with the non-depressed area next to the oval? The reason I'm asking is because I heard from some users here that some late '86s had the revision for the 4.0 firewall but I didn't know if the front crossmember would be like the '87+ or still like the '86-, ie, both go hand in hand. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted July 20, 2013 Author Share Posted July 20, 2013 Ok, I looked at some previous threads covering this topic. I see where the difference lies. Not sure why I didn't quite catch it the first time. http://comancheclub.com/topic/31039-big-swap-help/?p=314518 Link to comment Share on other sites More sharing options...
