New Comanche Owner Needs Help Identfying His Suspension.
I'll post pictures soon. And no the track bar was not fitting so I put the new one on. Everything is good now except those drop brackets. It would have probably lifted it a little bit more. It's sitting at about 5" right now in the front. Haven't started on the back yet.
I hate to keep burdening you all with questions and my inexperience but is the spring over axle doable without welding? I can't find a welder here in my town and I don't want to buy one. Or can I do it and not off road and take it easy until I can weld it? It's my daily driver and right now its sitting with a godawful rake with the front jacked up.
don't wory about the questions we all are here for the same reasons.
To do a spring over you must weld the new perches on. If you can remove the axle and do the prep work your self ( gringing off the old perches, and locating the new ones) you could probably get a shop to weld it together fairly cheap. A muffler shop can probably do it.
