Just got a '92 NP242J out of a '92 4.0 HO, automatic. What I want to put it into: 1990 4.0 AX15. Will I have to switch out the shaft? I believe it's a 23 spline, I'm just not sure about the length.
AFAIK, the AW-4 case shafts were longer, so you should be able to put it on an AX-15 as long as it slides on all the way.  The input shaft on the T-case would hit the C-clip for the output shaft's 5th gear if it was too long, but I don't think it will be.  Someone else should be able to verify.
if you plan to run full time 4wd I would look into V8 ZJ cv style shafts.. I have some, (and a couple pics on my build thread) it will make turns smoother while in 4wd,  the shafts are simple to swap.  you can keep the U-Joint shafts as backups if they are in good shape
