64 Cheyenne Posted June 27, 2013 Posted June 27, 2013 Did a 4" drop on my 91 S-10, spindles in the front, blocks in the back. 2.5 and 5 speed I now want to take it the alignment shop that is 100+ miles away. Can anybody give me the alignment specs so I can have it in the ballpark for the trip? Caster Camber Toe
mvusse Posted June 27, 2013 Posted June 27, 2013 http://www.autozone.com/autozone/repairguides/S10-Pickup-Sonoma-2000-2004/Specifications/Wheel-Alignment-Specifications/_/P-0996b43f80371638
danbyrambler Posted June 27, 2013 Posted June 27, 2013 100 Miles to an alignment shop - WOW! - Might want to consider this - - Cost of Equipment minus cost of trip minus shop charge makes for a bargain IMO http://www.quicktrickalignment.com/ Saw it on Speed / Truck U & bought the Pro version since I don't need the camber stuff & caster is simple enough without the digital gauge - I like it - besides, It's another tool! - - May add the digital stuff later for my PITA Rampage project - - - Anyway, some good info on the site as well - - - Search is a good tool - Lots of DIY alighnment here on CC & it isn't hard to do :wrench:
64 Cheyenne Posted June 27, 2013 Author Posted June 27, 2013 Aint askin HOW, just needed the specs, but thanks for the info.
knever3 Posted June 28, 2013 Posted June 28, 2013 If you haven't found your answer call Belle Tire, they use the Hunter 600 series alignment machine. Their data base will have the specs. Give them a call and they will tell you or give you a copy.
