Proper Cleaning Of Electrical Terminals Question
I'm curious about the proper cleaning of electrical terminals on our MJs. They seem to really gunk up, sludge up, and tar up quite heavily over time. Here in Alaska, a can of electrical parts cleaner costs around 7 bucks, which is far too much to blow through them regularly. So I'm curious if you can use a kerosene pumping parts cleaner to soak/clean out the electricals, then spray off the consequential residue with the electrical parts cleaner. Anyone know if it's safe for the electricals?
I always use Fantastic cleaner, and for the really tough spots I use a small anount of naphta on a rag. Cruiser54 has a lot of knowledge and perhaps will chime in with a better idea.
Kerosene...dunno but as you say, I'd spray it down really well with electrical parts cleaner after.
For all of my electrical connections, I wire brush them a little, then use rubbing alchol. This does not harm the electronics and is a great cleaning solution. For hard to get places like the inside posts of relays, I use Q-tips with some alchol on it. After the alchol dries up, I dap some di-electric grease to keep the posts nice and clean from outside elements.
