Coil Spring Isolators
You should be able to squirt some PB Blaster inside the coil mount from under the hood. You can also apply some heat to the coil mount to help things along.
They came out pretty easy in my '86 (once I figured out they were threaded in place), which has been in the rust belt since '86.
3ft Pipe wrench.   :yes:   I watched a video on installing coil spacers not that long ago and they made mention that some of these "bumper" dealybobs can be welded or simply non removeable. They were working on an 89 cherokee. However, i just added coil spacers to my 90 and they were a snap to remove with my good ole pipe wrench.
