Wiper Problem..
Hey guys
I was driving the other day in my truck and I turned the wipers on. They only went up about a 1/4 way up the windshield and stopped. I was like oh crap. Let me ten them off so they go down.. they didn't go down.
I could only get them down if I had the truck off and I pushed them down.. it does this eveytime I hit the wipers..
Bad switch?
Thanks
try yanking out the intermittent box. it's a small plastic box under the dash on the drivers side with a plug going in and a plug going out. remove the plugs and plug them into each other (which is how it is in non-intermittent trucks). that should tell you if the box is bad.
Is that box connected to the steering column? I couldn't find it when I went under there.. Maybe looking in the wrong place.. I took the cowl off and turn the wipers on. It seems like the motor is jammed or something.. It won't go passed 1/4 way at all. I can't move it manually unless the truck is off, but only going down..
  • 4 weeks later...
  • 5 months later...
Still worked with I took the box out and plugged the two together.. Still the same thing.. I took the motor out today and found that one of the 3 bolts that holds the linkage on came off and was stuck when it moved around..
THanks for the help.
