i just finished this thing last wk and i want to add a hoop tell me what u think
its hard to tell but thers about 2" between the bar and the hi-lift
definitely go with the hoop. but it looks wierd with the bumper ends because they don't fit into the front...maybe make a piece of sheet metal to fit there and make it look better? that's my only beef lol...
no hoop! i like it sans hoop.
well, i change my mind... with the round lights the hoop looks better than those lights with no hoop. so, HOOP!
i like it, i would make the hoop detachable soyou don't have to take your whole bumper off to take the grill out. did you beef up the factory mounts any cuz there really puny lol.
i like the bumper, but i would taper the bottom outside corners up for better ground clearance and approach
on my brothers with the winch in front of the grill you've got to undo the grill and slide it out the side like a rear-slider window. you should be able to get it out like that, his winch is alot closer than that hoop looks.
I'm gonna do that when I'm done with the suspension so hopefully by this summer
its held on by 8 grade 8 bolts on each side and i got rid of those stupid "nut clip" and used real nuts
for everything except the hardware hooks and lights it only cost me about 20bucks
