Willymakeit Posted May 13, 2013 Share Posted May 13, 2013 I just bought a 1 owner,rust free me out of Arizona. 4.0,5spd. Has a dana44 in the rear with a rebuilt motor. Seems to run fine but the 3.07 gears kill it. Have built a lot of cars but not 4 wheel stuff. Here is what I use it for, mainly going fishing so I don't need a crawler. I've seen the soa which I can do but remain confused as to what springs to use in the front. I can build control arms ect. I'm not concerned about ride, I drive a lot of 50's era straight axle trucks. What is a spring I can get from the salvage yd or order new? Thanks in advance. I will match tires and gearing at the same time. Link to comment Share on other sites More sharing options...
Eagle Posted May 13, 2013 Share Posted May 13, 2013 Back up and start at the beginning. First, how do you plan to use the truck? Second, what size tires do you plan to run? Third (and well after the other two questions have been answered), how much lift you you think you need? Ideally, you want the least amount of lift that will get you where you're going. You can run 31x10.50s in factory rims with NO lift, and that's probably enough to get you to most fishin' holes right there. A spring over conversion is going to lift the rear by around 5-1/2 inches, which means doing a lot to the front to lift it my a comparable amount. Link to comment Share on other sites More sharing options...
87manche1 Posted May 13, 2013 Share Posted May 13, 2013 Front lift above 3 inch ull need trackbar, control arms or control arm brackets or both, shocks, swaybar endlinks ect. To me I like around 4.5 costs can vary 450-700 depends who u go with Link to comment Share on other sites More sharing options...
Lee21490 Posted May 13, 2013 Share Posted May 13, 2013 http://www.experimentalinsanity.com/vehicle/resources/mj-lift.html This is what i'm in the process of buying. The coil springs come tomorrow :3 Link to comment Share on other sites More sharing options...
Lee21490 Posted May 14, 2013 Share Posted May 14, 2013 http://www.experimentalinsanity.com/vehicle/resources/mj-lift.html This is what i'm in the process of buying. The coil springs come tomorrow :3 These are some burly @$$ springs man. Link to comment Share on other sites More sharing options...
92tanMJ Posted May 16, 2013 Share Posted May 16, 2013 You can also use tbird coils to lift the front 4.5.. thats what I have on my XJ and I'm going to use on my MJ Link to comment Share on other sites More sharing options...
jpdriver1 Posted May 16, 2013 Share Posted May 16, 2013 what rear spring packs does it have? if it was stock with the d44, you should have the metric ton (5 leaf) packs --- adding deaver overloads will give you about 3" in the rear --- Link to comment Share on other sites More sharing options...
