Slifter Posted April 27, 2013 Share Posted April 27, 2013 Heading to the wreckers shortly to find a stock replacement. I tried an electric fan but it is way too loud and I don't trust it. Long shot question here but, other than Jeeps, does anyone know what other vehicles share the same fan? Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted April 27, 2013 Share Posted April 27, 2013 Maybe any S-10 or any other rear wheel drive Chevy/GMC that use the 2.8/3.1/3.4, etc. :dunno: Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 28, 2013 Share Posted April 28, 2013 A 2.8 MJ XJ fan has more blades than a 2.5 fan, but I'm not sure if the threads are the same. I have one of each in storage, but I can't get to them at this moment to look at them. Might be an option though. Link to comment Share on other sites More sharing options...
jimoshel Posted April 28, 2013 Share Posted April 28, 2013 Been out checking. Used the following engines for comparison. 1985 2.5 XJ 1986 2.8 MJ 1987 2.5 MJ 1991 2.8 S10 1995 2.8 S10 1993 4.0 XJ The size. make year of engine has nothing to do with interchange. All V belts will swap. All serpentine belts will swap. Serpentine and V belt will not swap. The Vbelt pully is a hair bigger than the serpentine pully. It's so close that a couple swipes with a rat tail file in each hole will do it tho. This is fitting the pulley onto the water pump shaft. Not the fan blade to the fan clutch. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted April 28, 2013 Share Posted April 28, 2013 Jim's the man! I love this forum, everyone is so helpful. :cheers: Link to comment Share on other sites More sharing options...
Slifter Posted April 30, 2013 Author Share Posted April 30, 2013 Wow thanks, got one of of a YJ on the weekend. Seems to not run as cool... Link to comment Share on other sites More sharing options...
Slifter Posted April 30, 2013 Author Share Posted April 30, 2013 The fan I got is pushing not pulling so keep that in mind when using other fans off other vehicles you may not get the correct rotation. Edit: Fixed the hole in the shroud and power timed it (was way off), running cool now. Now onto the drive train vibration... Link to comment Share on other sites More sharing options...
