CoryMJ89 Posted April 26, 2013 Share Posted April 26, 2013 Ok so I'm getting ready to set up dual doubles what ever you want to call them... I'm gunna run two np 231s I found another 231 out of what my buddy says came out of a 4cylinder 93 Cherokee so my question is does that mean its different than a 6cylinder truck bc different tranny's ?? and are all interchangeable? And all 91 and new tcase are all 23 spline as far as I know ? Thanks Link to comment Share on other sites More sharing options...
mvusse Posted April 26, 2013 Share Posted April 26, 2013 All 231s behind the AX4 or Ax5 (4 cylinder manual transmissions) were 21 spline regardles of year. But worse, both for 21 spline and 23 spline there are three different length input shafts. Not only do you need to correct spline count for your transmission, you also need to correct length. Right around 94 they changed a few things inside the case. One difference is that it will have a true neutral, whereas the older ones in neutral lock the front and rear output shafts together. Another difference is the cur of the gears. Because of that input shafts can be swapped between older ones, or they can be swapped between newer ones. But an older input shafts will not work in a newer case, nor will a newer input shaft work in an older case. Link to comment Share on other sites More sharing options...
zackcj7 Posted April 26, 2013 Share Posted April 26, 2013 This webpage has a pretty good break-down. http://www.novak-adapt.com/knowledge/np_nvg_input_gears.htm Link to comment Share on other sites More sharing options...
CoryMJ89 Posted April 26, 2013 Author Share Posted April 26, 2013 I have a 94 tcase right now but the other one is a 93 out of a 4 cylinder idk which tranny it had behind it tho Link to comment Share on other sites More sharing options...
mvusse Posted April 26, 2013 Share Posted April 26, 2013 I have a 94 tcase right now but the other one is a 93 out of a 4 cylinder idk which tranny it had behind it tho I know both the AX4 and AX5 use the same input shaft since they are basically the same transmission. The AX4 is just missing the gears and shift rail for 5th gear. Don't know what an automatic transmission behind a 4 cylinder got, but those are few and far between. Link to comment Share on other sites More sharing options...
JFAComanche6 Posted April 26, 2013 Share Posted April 26, 2013 How does this work? I'm gunna run two np 231s Link to comment Share on other sites More sharing options...
mvusse Posted April 27, 2013 Share Posted April 27, 2013 Half a 231 (just the gear reduction housing) between the transmission and whole transfer case. high 2wd = normal 2wd low 2wd = low range 2wd (not available with just one case) high 4high = normal 4wd high 4low = 2.72 low range 4wd low 4 high = 2.72 low range 4wd low 4low = 7.40 super low range 4wd (not available with just one case) Now if you install a terra-low kit in one of them, your available ratios will be 1:1 2.72:1 4:1 10.88:1 Link to comment Share on other sites More sharing options...
CoryMJ89 Posted April 27, 2013 Author Share Posted April 27, 2013 How does this work? I'm gunna run two np 231s Dual cases or other known as doublers Link to comment Share on other sites More sharing options...
mnkyboy Posted April 27, 2013 Share Posted April 27, 2013 Dual 231s is a bad idea. The output torque from the first case is way more then the second case can handle, you can double them but the second case won't live very long. Link to comment Share on other sites More sharing options...
CoryMJ89 Posted April 27, 2013 Author Share Posted April 27, 2013 Hmm haven't heard of that before Link to comment Share on other sites More sharing options...
CoryMJ89 Posted April 27, 2013 Author Share Posted April 27, 2013 What would break Link to comment Share on other sites More sharing options...
mnkyboy Posted April 27, 2013 Share Posted April 27, 2013 From what i understand usually the aluminum case explodes. You figure the torque of the engine is multiplied by your transmission then again in the t case, a 231 is only rated for 1885lbs max torque which should be way less then what's gonna be coming out of the first case in low range. Link to comment Share on other sites More sharing options...
CoryMJ89 Posted April 27, 2013 Author Share Posted April 27, 2013 But does it grenade bc ppl aren't running another support cross member ? Link to comment Share on other sites More sharing options...
CoryMJ89 Posted April 27, 2013 Author Share Posted April 27, 2013 Bc no company makes a dual case crossmember for the jeep yet Link to comment Share on other sites More sharing options...
mnkyboy Posted April 27, 2013 Share Posted April 27, 2013 It just can't handle the stress that's going on inside of it. Have you even got lockers and gears yet? Link to comment Share on other sites More sharing options...
mnkyboy Posted April 27, 2013 Share Posted April 27, 2013 Bc no company makes a dual case crossmember for the jeep yet Most of the guys with rigs that can make use of a doubler are more then capable of building a simple crossmember. Link to comment Share on other sites More sharing options...
CoryMJ89 Posted April 27, 2013 Author Share Posted April 27, 2013 Oh we'll just jeeps ive seen they had no crossmember Link to comment Share on other sites More sharing options...
