nicholasdances Posted March 13, 2013 Share Posted March 13, 2013 it doesn't look like I can pull another one of these out of any 4.0 or even the 2.5 yj's (according to part numbers on autozone) anyone know if there is another jeep with a compatible starter? Link to comment Share on other sites More sharing options...
mnkyboy Posted March 13, 2013 Share Posted March 13, 2013 I don't know why any Jeep 2.5l starter wouldn't work. Most likely the 2.8l starter would work too. Link to comment Share on other sites More sharing options...
nicholasdances Posted March 13, 2013 Author Share Posted March 13, 2013 ya that's what I thought originally but the part numbers don't match up. it might fit anyways I guess. I agree with the 2.8 but those things are IMPOSSIBLE to find. Link to comment Share on other sites More sharing options...
jimoshel Posted March 13, 2013 Share Posted March 13, 2013 Take the two. Set them side by side and compare. I agree with the 2.8 but those things are IMPOSSIBLE to find. How many do ya need? Link to comment Share on other sites More sharing options...
Geonovast Posted March 13, 2013 Share Posted March 13, 2013 I don't see why you couldn't use any 2.5 Starter. There may be differences with different part numbers, but that doesn't mean they're not swappable. The 2.8 starter might not, can't say for sure, I've never worked with one. It's feasible it mounts to the block differently. Link to comment Share on other sites More sharing options...
jimoshel Posted March 13, 2013 Share Posted March 13, 2013 Well Dern. I sit a 2.8 and a 2.5 starter side by side and was going to take pics and compare. Got started doing something else and for got all about them. Have it tomorrow. Promise. Link to comment Share on other sites More sharing options...
jimoshel Posted March 14, 2013 Share Posted March 14, 2013 The Jeep 2.5 and Chevy 2.8 will not interchange. The 2.8 mounting bolts are vertical, bolts into the block. The 2.5 are horizontal, bolts into the bell housing. As many of them things as I have replaced, i should have remembered it without having to go look. The Jeep 2.5 and 4.0 starters are physically similar and will interchange. Electrically the 4.0 will probably have heavier windings. Going to tear a couple apart and compare later today. We'll see. Link to comment Share on other sites More sharing options...
nicholasdances Posted March 15, 2013 Author Share Posted March 15, 2013 thank you!! Link to comment Share on other sites More sharing options...
Geonovast Posted March 15, 2013 Share Posted March 15, 2013 The Jeep 2.5 starter does not bolt into the bellhousing. It bolts into the block. If you look at an AX-4/5 bellhousing, you can see there's no bolt holes for starter. Link to comment Share on other sites More sharing options...
mnkyboy Posted March 15, 2013 Share Posted March 15, 2013 The Jeep 2.5 starter does not bolt into the bellhousing. It bolts into the block. If you look at an AX-4/5 bellhousing, you can see there's no bolt holes for starter. This is correct, the bolts on mine go straight up like a GM. Link to comment Share on other sites More sharing options...
jimoshel Posted March 15, 2013 Share Posted March 15, 2013 Dog gone it Corry. I had to go out and look. The bottom bolt goes thru the starter into the bell housing. The top bolt goes thru the bell housing into the starter. Link to comment Share on other sites More sharing options...
mnkyboy Posted March 15, 2013 Share Posted March 15, 2013 This is a 2.5l starter. Link to comment Share on other sites More sharing options...
jimoshel Posted March 15, 2013 Share Posted March 15, 2013 It's to dark now to see anything. Going to take another look tomorrow. Link to comment Share on other sites More sharing options...
jimoshel Posted March 15, 2013 Share Posted March 15, 2013 Well, I looked. The 2.5 starter does mount with two bolts going up into the block. Wondering where I went wrong there. I looked at a 2.5 block I had on the ground and didn't believe a bolt that small could hold a starter. Solved one problem but created another one. I have 11 starters on the shelf all marked 2.5. So how did they get marked that way and what are they off? The 2.5 and 2.8 still will not interchange. The Jeep is inline bolt pattern and smaller than the Chevy staggered pattern. Note to self. When Corry says something. take his word for it. LOL Link to comment Share on other sites More sharing options...
mvusse Posted March 16, 2013 Share Posted March 16, 2013 Thought I was losing my mind here, as I've had the transmission off my 2.5 a number of times now, and have never had to take the starter off. Glad we at least have that all cleared up. Link to comment Share on other sites More sharing options...
