zackcj7 Posted March 6, 2013 Share Posted March 6, 2013 I have a AX4 with external slave on my MJ. It's the older style slave on the passenger side. Sometimes when I push in the clutch the shifter will not go in any gear. If I cut the motor it goes into gear fine. I'd like to bleed the clutch and see if that helps. I can't find the bleeder valve on the slave so I assume it's on the top. Will I have to pull the master and slave and bench bleed or is there a way to bleed these on the vehicle? If this isn't the problem my next guess would be a seized pilot bearing. Do the AX4s use a pilot bearing or a bushing? Link to comment Share on other sites More sharing options...
Geonovast Posted March 6, 2013 Share Posted March 6, 2013 You can bleed in the truck, but the externals must be removed from the bellhousing, and kept compressed during the bleed. There's a special tool for it, but you should be able to use half an exhaust clamp and a metal rod. Link to comment Share on other sites More sharing options...
zackcj7 Posted March 6, 2013 Author Share Posted March 6, 2013 You can bleed in the truck, but the externals must be removed from the bellhousing, and kept compressed during the bleed. There's a special tool for it, but you should be able to use half an exhaust clamp and a metal rod. So I unbolt the slave from the bellhousing, fix the piston so it stays compressed, and bleed as normal. Pump and hold bleed or gravity? Or I can borrow a vacuum bleeder if that would be better. Link to comment Share on other sites More sharing options...
Vintage Posted March 6, 2013 Share Posted March 6, 2013 I have a AX4 with external slave on my MJ. It's the older style slave on the passenger side. Sometimes when I push in the clutch the shifter will not go in any gear. If I cut the motor it goes into gear fine. I'd like to bleed the clutch and see if that helps. I can't find the bleeder valve on the slave so I assume it's on the top. Will I have to pull the master and slave and bench bleed or is there a way to bleed these on the vehicle? If this isn't the problem my next guess would be a seized pilot bearing. Do the AX4s use a pilot bearing or a bushing? Remove the shifter knob, the cover, and the metal plate underneath. A 10mm socket (iirc) and about 8 inches of extension, and you can bleed it yourself sitting in the truck. Link to comment Share on other sites More sharing options...
zackcj7 Posted March 6, 2013 Author Share Posted March 6, 2013 Remove the shifter knob, the cover, and the metal plate underneath. A 10mm socket (iirc) and about 8 inches of extension, and you can bleed it yourself sitting in the truck. Man, that sure makes it easier. That slave cylinder is right above the cat converter and a pain to get to. Link to comment Share on other sites More sharing options...
