UNL1MTD Posted March 18, 2007 Share Posted March 18, 2007 Well, I was under the misguided impression that I had a good plan. Problem - 5 speed shift know spins on the '87 (project MJ). First thing I did was pull on it and it came right off. I noticed there was a nut on the bottom and a thread piece of metal that the knob probably clamped to at some time. :cry: Second thing I did was go to the '89 (parts MJ) and removed the shift knob, both 5 speeds, so what the hell. Noticed the Nut on this one was upside. 3/4" wrench, came right off. :D Third thing was to go to the '87 and remove its nut, started turning counter clockwise, was fairly stuborn, but its an '87 most bolts will be stuborn. 1 sec later the nut and threaded portion of the shifter are in my hand. :headpop: So what's next? Is there any way to remove just the tall portion of the shifter and replace it with one that has threads? At first sight its not overly intuitive. I'm not 100% on what trans I have, its a 5 speed under a '87 2wd MJ. Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted March 18, 2007 Share Posted March 18, 2007 BA-10/5 is your tranny unless its rockin' a 2.5L then its a AX-5 get the threaded rod out of the little aluminum threaded shaft and booger weld it back to the shift tower. you should be able to swap tranny shifters from ba-10 to ba-10. Not from Ax5 to ba-10. Link to comment Share on other sites More sharing options...
UNL1MTD Posted March 18, 2007 Author Share Posted March 18, 2007 get the threaded rod out of the little aluminum threaded shaft and booger weld it back to the shift tower. thats a good idea, sounds like the cheapest way to go about it. you should be able to swap tranny shifters from ba-10 to ba-10. Not from Ax5 to ba-10. you are talking about unbolting the actual shifter stick from the tranny and putting in a junkyard one? Is this easy to do. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 18, 2007 Share Posted March 18, 2007 you may also have an ax15 5 speed. just look at the base of yoru shifter and/or at your tranny, go to the junkyard and find one that looks the same, and buy the shifter off it. then install it on yours Link to comment Share on other sites More sharing options...
jeepthing07 Posted March 19, 2007 Share Posted March 19, 2007 The same thing happend to my shifter. I stuck the shifter in a drill press and drilled and taped it. then threaded a 3/8-16 stud into the shaft and stuck a new shift knob on it. i dident get the hole perfectly centerd but it's very strong I'm not worried about it coming off again. Link to comment Share on other sites More sharing options...
Eagle Posted March 19, 2007 Share Posted March 19, 2007 you may also have an ax15 5 speed. Unlikely in an '87, unless a previous owner swapped it in. The AX-15 didn't start until midway through the 1989 model year. Link to comment Share on other sites More sharing options...
