I'm thinkin about the motive link seems to have good prices alot cheaper then Randy's ring and pinion and u said the 4-1 kit or thinkin duals?
I'll post of there about the dual I want to do the d300 and 231 but if I have to ill do the 231 with another 231 just regear them but the d 300 u can do a twin stick right?
Remember the lower you go in gear ratio (higher numerically) the smaller the pinion shaft is going to be. In a D30 w/35's+, that'll be your weak link. What a PITA to change versus axleshaft u-joints.
Toss in a crawl box for the rocks/climbimg and keep good street manners too with a set of 4.10's-4.56's.
The 231 to 300 would be best.
The issue with doubling 231s is once the torque is multiplied by the first case it now exceeds the maximum torque of the second case so you run the risk of braking it.
It might be easier to run a 4.1:1 in your current case. Also if you go to a D44 you can go as high as 5.89 in the axles, depending whats available for the rear axle.
If you under geared you will find yourself hitting obsticles with more speed which isnt gonna be good with your current setup
Yeah I know the pinion gear gets small easier to snap I really wanna do the 4.56-37s but everyone on here is against it
I had motive gears in my past YJ on 37s and my current comanche on 37s with dana 44s, all have been 5.13s, detroits........they take a beating!! No regrets yet. I also used their install kit, bearings, shims, all went well.
Minimum install kits are about $40 they come with shims, pinion seal, marking compound, and a cover gasket.
A full kit is around $100-$150 and comes with everything the minimum kit has plus new carrier bearings and pinion bearings, depending on axle they can come with other bearing and seals as well.
Not sure on your 8.8 but since you have 3.07s you will need a new carrier for your D30 they are about $70-$80.
If I was going to run 37s on my Dana 30 (which I would never do) I would run 4.56s. The 4.88 only has one tooth on the pinion contacting the ring gear. Everybody I've seen blow up a Dana 30 R&P was running 4.88s.
1 tooth? how many would a 4.56 have? just seems odd to me
