Trying To Identify A Winch
mnkyboy
I recently bought a rig with an old WARN winch, the PO burned it up and just looped the cable around it.
I want to figure out what model it is so I can figure out if its worth fixing and so I can get parts.
The tag is destroyed but here is some pics.
Looks like a Belleview winch that was made from 1959-1973. http://www.ih8mud.com/tech/oldwarn.php
This is one of the first electric winches that phased out the older PTO driven styles. Essentially, they put a starter motor on a set of gears to drive it.
edit, I bet you can take the motor off and a good starter or alternator shop should be able to rebuild it. The rest of the winch shouldn't be too complicated to take apart and clean or repair.
